What gears?????
Old May 5, 2012 | 2:23 AM
jweber0872's Avatar
Default What gears?????
I have an 2004 chevrolet silverado 1500 with a 5.3L engine and have had no luck locating my gear ratio on this transmission. Can someone please designate what gear this is or how I may determine this???
Old May 5, 2012 | 2:25 AM
jweber0872's Avatar
the truck is also a 4x4 with the towing package
Old May 5, 2012 | 1:05 PM
country_09's Avatar
Probably 3.73s with it bein 4x4. Search google for the RPO codes and see what you have
Old May 6, 2012 | 8:12 PM
Gundog's Avatar
I agree,most likely 373s. You can take your vin to any dealer and the will tell you. OR, you can jack your rearend up, put a mark on the driveshaft and one on your tire. Rotate the tire one full circle while counting the full number of turns the driveshaft makes. most likely your driveshaft will make 3 full rotations and 3/4 of the last rotation=3.73, if the driveshaft rotates just a little past 4 full rotations then you have 4.11.
BassinProf
Oct 22, 2007 10:38 AM
SuperTexan
10
Oct 8, 2007 11:53 PM
justingazda
May 21, 2007 11:07 PM
WCURoverD90
Sep 8, 2006 12:06 AM
MuskyHunter
Aug 29, 2006 3:06 PM
