What kind of running gear do I have??
Ok, so I have a '98 silveradok1500 with the Z71 off-road package, 4.3, and 5-spd. I'm just wondering if there is a vin decoder on this site or anything that can help me identify my rear-end, gear ratios, trans, transfer case, etc.
It should be on the build sticker usually located in your glovebox. There is another thread here that has what the 3 letter codes stand for.
Hi! Can anyone direct me to the thread that has the definitions for the 3 letter codes in the glove compartment?? I found it once, but didn't save it ...
Thanks for any help!!
This is notthe link thatyou asked for, but it has the info that you are looking for.
Model Year:
http://www.angelfire.com/ca/TORONTO/VIN/VIS.html#year
Chevrolet Specific Codes:
http://www.angelfire.com/ca/TORONTO/VIN/chevrolet.html
You can find the codes on a sticker usually located in your glove box. Also, on your differentials, there will be a tag help on by a cover bolt. It will have have stamped on it something like "8.8 3 42" which is an 8.8" diameter ring gear at 3.42 ratio.
I hope this helps.
Model Year:
I hope this helps.
http://www.fullsizechevy.com/forums/...odes-here.html
check out this site: has differential codes and other stuff
ldeleiss
23
March 5th, 2023 8:24 AM
Mad Max 26
December 12th, 2009 12:19 PM
MaLiBu o9
June 17th, 2009 3:32 PM
EvansBlue
15
May 4th, 2009 10:57 PM
guvner
November 15th, 2007 9:22 AM
