What kind of running gear do I have??
Old Nov 27, 2007 | 12:56 AM
hines182's Avatar
Default What kind of running gear do I have??
Ok, so I have a '98 silveradok1500 with the Z71 off-road package, 4.3, and 5-spd. I'm just wondering if there is a vin decoder on this site or anything that can help me identify my rear-end, gear ratios, trans, transfer case, etc.
Old Nov 27, 2007 | 1:24 AM
engine2's Avatar
Default RE: What kind of running gear do I have??
It should be on the build sticker usually located in your glovebox. There is another thread here that has what the 3 letter codes stand for.
Old Feb 10, 2008 | 9:06 PM
poohbearb4u's Avatar
Hi! Can anyone direct me to the thread that has the definitions for the 3 letter codes in the glove compartment?? I found it once, but didn't save it ...
Thanks for any help!!
Old Feb 12, 2008 | 7:38 AM
mygreenihc's Avatar
This is notthe link thatyou asked for, but it has the info that you are looking for.
Model Year:
http://www.angelfire.com/ca/TORONTO/VIN/VIS.html#year
Chevrolet Specific Codes:
http://www.angelfire.com/ca/TORONTO/VIN/chevrolet.html
You can find the codes on a sticker usually located in your glove box. Also, on your differentials, there will be a tag help on by a cover bolt. It will have have stamped on it something like "8.8 3 42" which is an 8.8" diameter ring gear at 3.42 ratio.
I hope this helps.
Old Feb 14, 2008 | 8:24 PM
wellmax's Avatar
http://www.fullsizechevy.com/forums/...odes-here.html
check out this site: has differential codes and other stuff
ldeleiss
23
Mar 5, 2023 8:24 AM
Mad Max 26
Dec 12, 2009 12:19 PM
EvansBlue
15
May 4, 2009 10:57 PM
guvner
Nov 15, 2007 9:22 AM
