what is this part?
Old Dec 8, 2012 | 6:48 PM
smokinmoses's Avatar
Default what is this part?
Im gonna try and load a pick of this part its right above my skid plate and its leaking some kin of oil. Sorry for being a noob. My front drive axle links into it
Old Dec 8, 2012 | 6:49 PM
Dont know how to post pic :-(
Old Dec 8, 2012 | 6:55 PM
http://db.tt/kEngSnvv heres a link to the poc in my dropbox i promise its safe i really need help identifying it so i can fix it
Old Dec 8, 2012 | 7:25 PM
country_09's Avatar
Your front differential?
Old Dec 8, 2012 | 7:27 PM
I think so looked at it better and thats what its bolted to should just be a bad gasket hope its not too hard to fix
Old Dec 8, 2012 | 8:04 PM
there is no gasket for the case. they use a anerobic sealant.
When the fluid leaks everywhere like what you have; I'd wash it all off. drive it and re-check. then you can tell exactly where its from.
Old Dec 8, 2012 | 8:46 PM
I can pretty much tell its coming out around those bolts. Is there anyway to fix it?
Old Dec 8, 2012 | 11:20 PM
drain the diff
mark and remove the right stub shaft
remove the right side of the front diff
clean and apply the proper sealer
Old Dec 8, 2012 | 11:29 PM
Thank U man. U are very much appreciated
Old Dec 9, 2012 | 9:20 AM
to clarify:
if your splitting the case, the diff will have to come out. If its just at the acutator/axle shaft (you can see 3 of the bolts in the pic) you can leave the diff in the truck.
