what trannys fit a 2000 silverado 1500?
hello all, I have a 2000 silverado 1500 4x4. the tranny goes in reverse but not forward at all. I am thinking of buying a used transmission for it but am not sure what years and models will be a direct fit. I am looking at a 1999 c2500 single cab transmission. will that be a direct fit? am not sure. any help would be great. thanks epi
I have a 2000 Silverado 1500 4x4 and the transmission lost 3,4,and overdrive,I bought a rebuilt that I was told was an HD rebuild,after installing it I found out it only had first gear,I swapped the servo and then I had first and second,but the fluid went from bright red dex.6 to burnt dark fluid,the guy promised me a new transmission but I never seen him again so I bought a 1999 Tahoe 4x4 for the transmission,now my Silverado has a vortec engine and the Tahoe doesn't,both transmissions are 4L60E's but before I go through the trouble of pulling the tranny out of the Tahoe I sure would like to know if they can be interested,if any body know for sure could you let me know,thanks
I have a 2000 Silverado 1500 4x4 and the transmission lost 3,4,and overdrive,I bought a rebuilt that I was told was an HD rebuild,after installing it I found out it only had first gear,I swapped the servo and then I had first and second,but the fluid went from bright red dex.6 to burnt dark fluid,the guy promised me a new transmission but I never seen him again so I bought a 1999 Tahoe 4x4 for the transmission,now my Silverado has a vortec engine and the Tahoe doesn't,both transmissions are 4L60E's but before I go through the trouble of pulling the tranny out of the Tahoe I sure would like to know if they can be interchanged
I just recently did the same thing.. i am having trouble with it shifting ,,i think the pins maybe different i am trying to find out if anyone out there may know i sure could use the info.. you will have to switch bell housing out other than that and trying to figure out if this is the problem
ix3oh3xi
August 30th, 2010 11:12 PM
dannyboy11
December 19th, 2009 7:25 PM
00, 1500, 2000, 4l60e, 4x4, chevy, compatible, fit, forums, silverado, tranny, trannys, transmission, transmisson, years
