what trannys fit a 2000 silverado 1500?
Old Jun 2, 2010 | 11:10 AM
diendo's Avatar
Default what trannys fit a 2000 silverado 1500?
hello all, I have a 2000 silverado 1500 4x4. the tranny goes in reverse but not forward at all. I am thinking of buying a used transmission for it but am not sure what years and models will be a direct fit. I am looking at a 1999 c2500 single cab transmission. will that be a direct fit? am not sure. any help would be great. thanks epi
Old Jun 2, 2010 | 11:58 AM
LARIDERS's Avatar
your trans should be a 4l60e a 2500 truck should have the 4l80e and would not fit.
Old Jun 3, 2010 | 11:33 PM
diendo's Avatar
Default what years would it fit?
understood that, just wondering what years are compatible with a 1500 series? thanks
Old Jun 5, 2010 | 3:11 PM
country_09's Avatar
any of the 99-02 years will work as long as its the 4l60e tranny...so i'm not sure if the 2500 tranny your lookin at will fit or not
Old Sep 5, 2017 | 2:02 AM
dstanford's Avatar
Default 4L60E swap from a 1999 Tahoe to a 2000 silverado
I have a 2000 Silverado 1500 4x4 and the transmission lost 3,4,and overdrive,I bought a rebuilt that I was told was an HD rebuild,after installing it I found out it only had first gear,I swapped the servo and then I had first and second,but the fluid went from bright red dex.6 to burnt dark fluid,the guy promised me a new transmission but I never seen him again so I bought a 1999 Tahoe 4x4 for the transmission,now my Silverado has a vortec engine and the Tahoe doesn't,both transmissions are 4L60E's but before I go through the trouble of pulling the tranny out of the Tahoe I sure would like to know if they can be interested,if any body know for sure could you let me know,thanks
Old Sep 5, 2017 | 2:08 AM
dstanford's Avatar
Originally Posted by dstanford
I have a 2000 Silverado 1500 4x4 and the transmission lost 3,4,and overdrive,I bought a rebuilt that I was told was an HD rebuild,after installing it I found out it only had first gear,I swapped the servo and then I had first and second,but the fluid went from bright red dex.6 to burnt dark fluid,the guy promised me a new transmission but I never seen him again so I bought a 1999 Tahoe 4x4 for the transmission,now my Silverado has a vortec engine and the Tahoe doesn't,both transmissions are 4L60E's but before I go through the trouble of pulling the tranny out of the Tahoe I sure would like to know if they can be interchanged
Can these two vehicles use the same transmission,can I swap the transmissions with no problems,what I'm trying to say is will everything fit without having to change anything,I know the tranny's on one are quick change lines and the other one isn't but if that's all I will have to change over than I'll be ok with that
Old May 4, 2021 | 12:58 AM
James Palmones's Avatar
I just recently did the same thing.. i am having trouble with it shifting ,,i think the pins maybe different i am trying to find out if anyone out there may know i sure could use the info.. you will have to switch bell housing out other than that and trying to figure out if this is the problem
ix3oh3xi
Aug 30, 2010 11:12 PM
dannyboy11
Dec 19, 2009 7:25 PM
25004x4hd
Oct 22, 2008 9:50 AM
vbob2
Aug 2, 2007 1:16 PM
