Wheel & Tire question...
Old Jan 8, 2011 | 9:22 PM
BayAreaChevyGuy's Avatar
Default Wheel & Tire question...
Can someone point me towards a guide on this....
I want change out my stock wheels and tires for something nicer. I want to get some say 18 or 19 inch wheels. What's the largest size tire I can put on my truck with these wheels at stock heighth.
& then also, Id like to keep the same aftermarket wheels for pre and post lift.... I assume these same 18 or 19 inch wheels could support the larger size mudd tires?
Thanks guys./
Old Jan 8, 2011 | 10:04 PM
RacerX's Avatar
Put on what? What do you have?
Old Jan 8, 2011 | 10:28 PM
I have stock 17'' wheels and tires.
Old Jan 8, 2011 | 11:54 PM
I want to put on some like I think it was 19 inch pro comp wheels with the biggest tires I can get at stock height. Don't know the measurements though....
Old Jan 9, 2011 | 8:12 AM
s34n's Avatar
is your truck 4x4? or 4x2? i have an 04 4x4 with 17s and 285 tires. a little bit of plastic had to be trimmed but not much. you could probably do 18s with a 285 and some trimming to the lower valance. 285s are somewhat similar to a 33" tire.
Old Jan 9, 2011 | 12:31 PM
Yeah I have an 05 4x4. Thanks for the info.
Old Jan 10, 2011 | 8:37 AM
Proud Infidel's Avatar
Default info
also you might want to put a leveling kit on your truck or atleast crank up the torsion links to fit a 285 under there...thats the cheap way to do it or, go for the spendy way, full suspension lift and long arm kit. with a lift you can fit a much meatier tire under there.
Old Jan 10, 2011 | 8:06 PM
s34n's Avatar
a leveling kit with kit and alignment is a little pricey. depends on how you want to go about it. theres 3 ways
1. new torsion keys, spacers for shocks. ride will stiffen up.
2. new keys, and 4 new shocks
3. new keys, 4 shocks and rear blocks.
Old Jan 10, 2011 | 8:08 PM
s34n's Avatar
i would say 265 is probably as big as you can go at stock height. i've heard that 18s-20s will give your truck a street look, if you will, without lifting the truck. if you lift the truck, clearly go with 20s to give it the off road look.
Old Jan 10, 2011 | 8:53 PM
The Off-Road look is the look I want for sure. LoL.
tonymacias
2007 - 2013 (GMT900)
Aug 21, 2012 9:50 PM
nj85z28
Jul 31, 2012 12:36 PM
