Where to find engine Mount 1996 K1500
Old Jul 14, 2010 | 1:44 PM
aapstealth's Avatar
Default Where to find engine Mount 1996 K1500
I have a 1996 k1500 with a 4.3. The truck has 2 broken motor mounts. I have searched everywhere and cannot find the engine mounts. I found a similar one but they only fit the c1500. These are not the typical gm engine mounts but Im sure someone else has had this problem before. Here is the design for the 2-wheel drive which is similar but will not work. If anyone knows where I can find one besides the dealership or how to fix them please let me know. Also these say they fit a k1500 but only bolt up to a c1500 frame
http://www.autopartswarehouse.com/de...WSEM-3044.html
Old Jul 14, 2010 | 1:58 PM
you cant fix a broken mount that I am aware of as it is a bonded piece of rubber to the 2 steel mounting plates.....
Why do you not want to get them from the dealer? cost?
its probably the last set you will ever need....also do the tranny mount while you are down there its probably bad also
Old Jul 14, 2010 | 2:51 PM
aapstealth's Avatar
That is the correct mount sir. The local dealer is wanting almost $178+ per mount
Old Jul 14, 2010 | 4:30 PM
maxxman04's Avatar
http://www.summitracing.com/search/y...s/?Ns=Rank|Asc
Old Jul 14, 2010 | 4:50 PM
Holly shiitake mushrooms... yeah I can see why you'd want an alternative....
Old Jul 14, 2010 | 7:32 PM
aapstealth's Avatar
New Update turns out the dealer quoted me on the 2wd mount. They no longer make a 4wd mount for the 96 4.3. I cant believe this no one makes a Chevy mount. Also I dont think any of these inserts will work (i might be wrong though). But if anyone knows of anything that might please Post or PM me thanks.
Old Jul 14, 2010 | 9:15 PM
here is another link you might want to browse
http://www.1aauto.com/search?words=motor+mount
Old Jul 15, 2010 | 8:05 AM
aapstealth's Avatar
Just checked there website and gave them a call. NO luck. Im not sure what to do on this one as It seems impossible to fab something up that will work because of this design and limited room .
FordOwner
Jul 29, 2012 2:16 AM
OE812
Mar 7, 2011 6:02 PM
Partin out S10
Apr 3, 2010 1:32 AM
furcioelbraveado
Dec 29, 2009 10:21 AM
Znelwonders
Feb 23, 2008 8:16 AM
