Will 4.1 gears work on 35" tires?
Old Oct 21, 2007 | 1:58 AM
BassinProf's Avatar
Default Will 4.1 gears work on 35" tires?
I'm thinking of adding a 6" lift and 35" tires to my 06 2500HD. It's got the 6L gas engine and 4.1 gears. Is it going to be too much of a dog at low RPMs with those gears? I use it mostly for towing a 2500 pound bass boat.
Thanks.
Old Oct 21, 2007 | 3:44 AM
shulamite's Avatar
Default RE: Will 4.1 gears work on 35" tires?
no. you will notice some loss of hole shot. but in a month it will seem normal. the 6.0 has so much power that it handles my 6000 lb donzi with ease. you will be able to calculate you new gear ratio by marking the wheel and drive shaft and comparing the number of rotations. i'm guessing 3.70 which is a good gear for all around use.
Old Oct 22, 2007 | 10:38 AM
MalibuMaxxSS's Avatar
it wont dog off the line the 6.0 with 4.10 will still launch you fine...and how does changing tires give you a new gear ratio....?
goyakpacking
May 9, 2015 7:51 PM
mukherjee_mk
Aug 28, 2012 11:18 PM
LeeA
Apr 13, 2012 4:28 AM
JHarris8732
Nov 10, 2011 11:25 AM
uncledave11
Sep 10, 2010 7:12 AM
