wiper delay
Old Mar 5, 2008 | 4:49 AM
03chevyrustbucket's Avatar
Default wiper delay
My 03 2500HD wiper motor sometimes keeps running when I have them on delay andyou can't even turn them off.
any ideas on whats wrong and how to fix.
Thanks
Old Mar 5, 2008 | 6:01 PM
RonH's Avatar
Default RE: wiper delay
Could be a bad switch or dirty contancts inthe multi-function switch (turn signal lever). Also look at possiblya bad connector in the wiring to the switch or maybe a cut/frayed wire in the wiring harness. Problem most likely inside the steering column at one of these.
Old Mar 5, 2008 | 11:43 PM
rms's Avatar
rms
Chevy has a small circuit board that controlls the wipers. It is not uncommon for them to overheat creating loose connections and intermittant problems similar to yours. You should be able to see discoloration or melted circuits if this is the problem. If you dont see any thing look elsewhere.
ruley73
Sep 15, 2017 8:11 AM
ramichael
Sonic (Aveo)
Oct 29, 2008 4:57 AM
mrbita
Mar 11, 2007 5:43 PM
VSTAHOE
Feb 27, 2007 6:04 PM
mudman
Jan 13, 2007 7:04 PM
