Z06 cam swap help.
Z06 cam swap help.
Okay, so I did some research and found that you can swap a Z06 cam into a 5.3 without needing to change a lot of other parts in order for it to work. The only thing I couldn't find is if you need to put different pistons in with reliefs for the valves. Any help would be appreciated.
Why not try a cam where you just need to replace valve springs and rods. And one that'll actually give you hp/tq numbers that would warrant a cam swap? Zo6 cam swaps from what I remember aren't really worth the work
do you have a suggestion for a cam that can be swapped in without doing a lot of other work? and also that is good for a daily driver? cause this truck is my daily driver, for now, and i still want it to be streetable but i want more power.
Do you want to upgrade the torque converter or leave it stock? That plays into cam decision a lot. Bout the biggest if go on a stock converter is 212/218 112lsa and some ls6 yellow springs. Awesome lower end power, great top end, and a good chop.
i am planning on rebuilding the tranny and upgrading the internals and possibly the torque converter, and i don't really pull stuff a lot but I do pull my father in-law's boat every weekend
Yes same thing, besides the lsa bein a 114 instead of a 112 anyways. But that'd be perfect for you. Would definitely plan on throwin some upgrades at te transmission. Stall, hd2 shift kit, vette servo and tranny cooler upgrade at the least
any recommendations for a torque converter? i already found a rebuild kit that'll hold up to 500 hp but i dont plan on it puttin out that much but the kit's only 500 bucks so might as well.
