Site Feedback THIS SECTION IS FOR SITE RELATED ISSUES ONLY!! NO TECHNICAL QUESTIONS OR ANYTHING RELATED TO FIXING AN AUTOMOBILE
1989 suburban.. please help
Old Oct 7, 2017 | 7:31 PM
Krisburb's Avatar
Default 1989 suburban.. please help
First,.. New guy.. Hello and great to be part of this site..
second... Please help!...89 burb, v1500, 5.7.. New parts: fuel pump, distributor, coil, spark control module, map sensor, temp sensor, EGR valve... Checked timing, fuel pressure, TPS, temp.. All checked perfect... Idles and revs perfect.. Problem lies when put reverse or drive, bogs down, sometimes misfires.. Put back in park, runs and revs fine... Also bogs with a/c on.,... Running out of ideas and parts to replace... Can't figure why it can't handle any load, but runs perfect in park.. Thank you for any help.. Kris
Old Oct 7, 2017 | 9:47 PM
Have a helper monitor the fuel pressure when you shift it into gear.
Old Oct 7, 2017 | 9:57 PM
Krisburb's Avatar
Checked fuel pressure running, idling and throttle up, neutral and in gear....13psi... Never fluctuated
Old Oct 7, 2017 | 10:05 PM
That sounds low but I'm not sure what it should be. Do you consider that to be adequate fuel pressure?
Old Oct 7, 2017 | 10:08 PM
Krisburb's Avatar
Book says spec is 9-15... From what I've read, anything lower than 11 is problematic.....
Old Oct 7, 2017 | 10:22 PM
Is that a throttle body or a fuel injection system?
Old Oct 7, 2017 | 10:24 PM
Krisburb's Avatar
A throttle bottle injection
Old Oct 7, 2017 | 10:52 PM
I didn't realize that throttle body injection required that low of a fuel pressure. That's not much more than a carburetor takes.
Old Oct 7, 2017 | 10:58 PM
Krisburb's Avatar
The multi port injection is like 60 pounds or something like that, but this one only has the two injectors..I thought it would've been higher also
Old Oct 8, 2017 | 12:15 AM
Yeah me too. Good luck on fixing it and let us know what you finally find.
