Site Feedback THIS SECTION IS FOR SITE RELATED ISSUES ONLY!! NO TECHNICAL QUESTIONS OR ANYTHING RELATED TO FIXING AN AUTOMOBILE
1998 silverado no fuel injector pulse
Old Aug 7, 2017 | 6:35 PM
Mathewryan's Avatar
Default 1998 silverado no fuel injector pulse
I have a 1998 silverado with a 5.7. It will run with starter fluid, but not on it own. I replaced the fuel pump, fuel filter, fuel pressure regulator, and cam sensor. The injectors have 12 ohms. And when i try to start it it has 12 volts at the plug, but it does not pluses ir just keep 12 volts the hole time. I dont have any security light on. I was thing it was the pcm but i dont wont to replace it if that not it. ?????
Old Aug 7, 2017 | 11:04 PM
Rednucleus's Avatar
ignition control module?
Old Aug 7, 2017 | 11:14 PM
Mathewryan's Avatar
If it was the ignition control module would it still get fire?
Old Aug 7, 2017 | 11:21 PM
Mathewryan's Avatar
I have between 60 and 65 psi of fuel pressure
Old Aug 8, 2017 | 7:31 AM
kevinkpk's Avatar
Sounds to me like the ecm
Old Aug 8, 2017 | 4:28 PM
Mathewryan's Avatar
that what i meant ecm not pcm. I cant see anything else it could be in the diagram but the ecm.
Old Aug 8, 2017 | 10:38 PM
Rednucleus's Avatar
when my icm dies on my 93 I have spark but no injectors, can run motor pouring gas down throttle body. On my 3rd one. 98 may be a different beast
Old Aug 9, 2017 | 12:49 AM
Mathewryan's Avatar
when my icm dies on my 93 I have spark but no injectors, can run motor pouring gas down throttle body. On my 3rd one. 98 may be a different best
i got a ecm coming in the mail it should be here Thursday. But if that doesn't fix the problem ill look into the icm. Thanks for your help.
Old May 20, 2020 | 5:26 PM
David Cook's Avatar
Default Same issue and lost
Did you ever figure out your problem. I have a 2000 GMC K2500 that is having this exact same issue. I have tried 3 ECUs and replaced everything fuel system and spark. Its as if the injectors are not firing.
Tony Martinez
Feb 23, 2020 2:14 PM
ve6bmw
Apr 17, 2018 8:52 PM
Steve1979
Mar 8, 2018 10:55 PM
vtchevy
Sep 28, 2016 2:45 AM
51StylelineDeluxe
Aug 30, 2012 9:14 AM
