Site Feedback THIS SECTION IS FOR SITE RELATED ISSUES ONLY!! NO TECHNICAL QUESTIONS OR ANYTHING RELATED TO FIXING AN AUTOMOBILE
brakes
Old Feb 26, 2014 | 11:51 PM
2heavychevy's Avatar
Default brakes
I have a chevy silverado c1500 1998. My brakes are going to the floor and my calipers are locking up. They were fine before but my rotors were bad and I replaced them. I also replaced my pads when I replaced the rotors. When I tried to test the breaks they went to the floor and before I got a block away the calipers were locking up. I thought that I might need to bleed the brakes but that wasn't it. I thought it might be the calipers so I replaced them. That didn't do it. So I replaced the rubber line running from the calipers to the hard lines. Not it. So I'm at a loss. I only have two things left that I can think of. 1.the master cylinder. 2.the break booster. If anyone has any knowledge on this problem PLEASE HELP....Thanks.
Old Feb 27, 2014 | 12:27 AM
'03 Heavy Chevy's Avatar
Is your brake booster the style that is powered by the power steering? If so, when is the last time you flushed the booster?
I've got a hydro booster system on mine (that is powered by the power steering pump). I flushed the system using this method.... Power Steering/Hydro-Boost Flush - Chevy and GMC Duramax Diesel Forum
It made a big difference. Like brand new. However, I waited until about 178k miles to flush mine (way too late).....my brakes have to pumped a couple of times tohave good pressure. So the next thing on my list is replacing the master cylinder....
Hope this helps!
JRich_taco
Aug 31, 2013 12:16 AM
Mille Racer 69
Dec 8, 2010 8:26 PM
Acardoctor
Corvette
Nov 26, 2005 7:23 PM
sixatd80
Oct 2, 2005 9:21 PM
southernrebel05
May 5, 2005 3:16 PM
