Sonic (Aveo) The subcompact known globally as the Aveo since 2002 is now the SONIC in North America as of the 2012 model
Chevrolet Sonic
GM Platform: T200, T250, T300
2005 Chevrolet Aveo...
Old Dec 4, 2013 | 7:06 PM
Sweetygirl2312's Avatar
Default 2005 Chevrolet Aveo...
Hello Guys!
I had an issue with my Aveo last night…I was driving on the highway when I saw some smoke coming out of my hood… I was close to home so I kept driving but once arrived, I figured that there was a leak in the engine…
My car was towed today at a mechanic and the diagnostic was:
-thermostat housing broken and to be replaced
How much does this type of work cost at dealership and other local mechanics?
Also, he said I will need to change the valve cover gasket.
How much does that cost? and how often should it be replaced?
Thanks!
Old Dec 21, 2013 | 4:22 PM
Aveo5_boy's Avatar
Thermostat is very easy to replace on these cars and I would suggest upgrading it to the aluminum housing to avoid any future blow outs. Valve cover gasket is also quite easy to do on these cars....a private mechanic could do this for a lot cheaper than the dealer.
Old Feb 8, 2014 | 7:55 AM
CRiver70's Avatar
hello, I have a Chevy Aveo 2005 with code no. results of P2610. Actually the car does not start the engine and the module was change but problem still. Do you know if a Computer problem ?
Old Feb 8, 2014 | 7:59 AM
CRiver70's Avatar
Default Engine can't start - Code P2610
My Aveo 2005 has an issue because don't want to start the engine. A test was done and identified that the injectors are not receive electric rigth now. I change the module thinking about issue with the module but the problem still. What about the P2610 ? Are this a computer problem ? Please, if any body has the same or experience same issue let me know will appreciate.
Thanks,
Jezah
Sonic (Aveo)
Aug 21, 2011 11:33 PM
pandadude
Sonic (Aveo)
Jan 12, 2010 6:59 PM
Hokearmy
Sonic (Aveo)
Jan 21, 2009 9:23 PM
AlexC.
Sonic (Aveo)
Jan 15, 2009 9:40 PM
