Sonic (Aveo) The subcompact known globally as the Aveo since 2002 is now the SONIC in North America as of the 2012 model
Chevrolet Sonic
GM Platform: T200, T250, T300
2005 thermostat housing leak (with photo)
Old Mar 8, 2014 | 9:20 AM
aveodrivers's Avatar
Default 2005 thermostat housing leak (with photo)
Hey guys, i know this is a common problem because of the cheap plastic
But I'm not sure if the housing is actually broken, or if i just need a sealant and gasket.
As you can see, these two pieces aren't staying togethor... so I was wondering if it's just a sealant/glue that's worn out...
Attached Thumbnails 2005 thermostat housing leak (with photo)-thermophto.jpg   2005 thermostat housing leak (with photo)-thermoph2-copy.jpg
Old Mar 8, 2014 | 11:13 AM
The only way to find out is to remove it and examine it. It could be the o ring or the housing could be cracked. I have seen both. They also make an aluminum one now. Check Rockauto.com
BlackAVEO
Sonic (Aveo)
Aug 17, 2015 4:34 PM
scottfarkus
Apr 25, 2015 8:18 AM
SilverK20A3
Nov 18, 2012 12:06 PM
hunterjo
Jan 1, 2012 8:23 PM
atikovi
Jun 12, 2011 9:23 PM
