Sonic (Aveo) The subcompact known globally as the Aveo since 2002 is now the SONIC in North America as of the 2012 model
Chevrolet Sonic
GM Platform: T200, T250, T300
How to remove OEM radio
Old Mar 17, 2010 | 3:00 PM
Toma.'s Avatar
Default How to remove OEM radio
Hi guys!
I have a 2007 Aveo and I want to remove my OEM radio (Blaupunkt GMDAT CDP). But I cannot figure it out how to do it.
Can you help me?
Photos will be perfect or tutorial.
Thanks
Old Mar 17, 2010 | 4:41 PM
nauticstar87's Avatar
First, i have never been in a Aveo, but I looked on Google how it's setup. You have the same radio I have in my truck. If you can pop off the dash, around the radio. There will be 4 bolts holding it in.
If your putting in aftermarket, How are you doing it??? It's a lil special compared to older vehicles.
Old Mar 18, 2010 | 1:02 PM
Toma.'s Avatar
Thanks. You can still paste some tutorial or photos, because I dont know exactly what to do.
I will see if I'll replace it.
How its made the aux in conector? Is the jack connector or something else? At the rear side of the radio?
Old Mar 18, 2010 | 3:21 PM
shawnvw's Avatar
Banned
For hatchback....pop the 2 panels off either side of the radio
For Notchback, remove the U-Shaped trim from around the radio.
In both cases, use PLASTIC pry tools so you do not damage the trim. Once the trim is off, there should be 4 phillips screws holding the radio in
Old Mar 20, 2010 | 10:18 AM
Toma.'s Avatar
Thanks for pictures. Can someone answer to my question that is bold typed?
Old Mar 21, 2010 | 2:46 PM
sergiuhusca's Avatar
Toma, the AUC connector is not a jack connector.
Is a mini-iso adapter, like this from the picture.
What do you want to say with "bold typed"?
Old Mar 22, 2010 | 9:17 AM
Toma.'s Avatar
nothing I got all the informations that i needed.
Or, how to change the mini-iso to jack connector?
bold typed --> How its made the aux in conector? Is the jack connector or something else? At the rear side of the radio?
This question I meant. Is this question typed with bold font, so it's bold typed or not? :-D
Old Mar 22, 2010 | 2:05 PM
Toma, now i understood what you want to say with bold type.
First time i was a little confused.I'm romanian citizen.I don't speack very well english.My intention was to help you.
TO transform tha mini iso in to a jack connector you need an adapter, hu change the RCA in to a Jack conector.
Old Mar 25, 2010 | 5:15 AM
Toma.'s Avatar
hehe, I have the same problem like you. I'm from Slovenia and my english is not brilliant, too. So I taught that I typed it wrong. thanks for your help.
Old Mar 25, 2010 | 4:02 PM
We welcome Toma.
If i can hepl you with another details about how to solv any problems with Aveo, PLEASE LET ME KNOW.
My yahoo ID is sergiuhusca!
