Sonic (Aveo) The subcompact known globally as the Aveo since 2002 is now the SONIC in North America as of the 2012 model
Chevrolet Sonic
GM Platform: T200, T250, T300
2006 aveo electrical issues
Old Dec 19, 2010 | 5:38 PM
Greg78's Avatar
Default 2006 aveo electrical issues
Out of the blue, passenger side parking lights came on with DRL's, dash lights and interior light quit working. Dealer replaced light switch. Now all
parking lights on with DRL's. Airbag warning light on. Pulled both parking
light fuses, lights are still on. Pulled IGN 2 fuse and lights went off.
Anyone else with this issue or ideas? Thanks.
Old Mar 5, 2011 | 9:31 PM
PBJT's Avatar
I know exactly what your problem is. Open the hood, remove the cover of the fuse block by the battery. and you will see on the left side of the fuse block a white connector 1/2 inch wide and 2 inches long, it will be melted and shorted causing your problem.
Old Mar 27, 2011 | 7:30 PM
archebald23's Avatar
Sounds like the auto light sensor relay is out, or the fuse is bad. One other thing to check would be your dimmer switch, on the left of the steering wheel.
If it's bad or unpluged your dash lights may not work.. just a thought before you take it in somewhere.
Chevrolet repair
Old Apr 19, 2011 | 6:48 PM
john2plus8's Avatar
get a relay
Old Jun 6, 2012 | 12:15 PM
sparky77's Avatar
Default have same issue
what is the purpose of this connector?? is it replaceable? there is black on one end of connector of my 06 aveo. issue is no dash lights.
Old Jun 6, 2012 | 12:22 PM
kevinkpk's Avatar
I believe the reference to the 1/2 wide "wire" is a fuseable link. I basically is the same as a fuse.
Sergio N Pamala Zavala
Sonic (Aveo)
Feb 26, 2015 11:25 PM
Rooster2657
Nov 27, 2012 9:23 PM
ondagaskiknass
Jul 1, 2007 1:59 PM
cbrace55
Sonic (Aveo)
May 3, 2007 9:06 PM
aveogyrl
Oct 28, 2006 12:46 AM
