Sonic (Aveo) The subcompact known globally as the Aveo since 2002 is now the SONIC in North America as of the 2012 model
Chevrolet Sonic
GM Platform: T200, T250, T300
2013 Sonic Won't start after pumping gas.
Old Jul 3, 2019 | 8:33 AM
  #11
Cadillac is a car brand...catalytic convertor is an emission component.
the part mentioned as faulty causing a hard start after pumping fuel is the purge solenoid valve.
Old Sep 15, 2019 | 6:39 PM
  #12
Michael Booth's Avatar
Default Problems after purge valve
so what if i have already changed the purge valve and still having issues starting?
Old Sep 15, 2019 | 9:55 PM
  #13
start a new thread in the appropriate section. list the model, year, engine. list the concern....what is happening...not what you think the fix is.
Old Sep 22, 2019 | 6:57 PM
  #14
Joyce Licorish's Avatar
Default 2013 sonic wont start after getting gas
I just bought a used 2013 chevy sonic runs great til you get gas and it doesn't want to start. I even tried leaving car running while getting gas but literally the car cuts out as soon as you remove the gas cap.
It starts eventually, then idles at under 1000 RPM and cuts back off again. Wont stay on unless you rev engine.
What wprked for younall with the same issue? Is there a recall that fixes this?
Old Sep 22, 2019 | 7:01 PM
  #15
Originally Posted by Laura Ratliff
Talked to a dealer service center and told him about the car not wanting to run well after putting gas. He said it was in the emissions system. But not the Cadillac converter so.not under warranty. Can I get the part name that would cause that problem.
Laura, what fixed the problem?
Old Feb 16, 2020 | 1:12 PM
  #16
Carmen Sandiego's Avatar
Originally Posted by DrUnKeN_TiGeR
I'm having this issue
​​​​​​... Is this the canister you talking about?
I changed this little bad boy and it fixed all my ailments of sputtering and hard start after getting gas. Also idling. Crazy how a small part would wreck such havoc.
Old Jan 16, 2021 | 6:06 PM
  #17
Tyler Hart's Avatar
Default 2013 sonic
im having this same issue and seems to be getting worse, did that part end up taking care of the issue?
mikee30
Uplander
Aug 21, 2017 1:47 PM
bridges1964
2007 - 2013 (GMT900)
15
Jul 26, 2016 8:39 AM
natalienug
Oct 14, 2015 8:26 AM
rz0y66
May 7, 2015 11:46 AM
Traverse
Traverse
Oct 5, 2014 10:23 AM
