Sonic (Aveo) The subcompact known globally as the Aveo since 2002 is now the SONIC in North America as of the 2012 model
Chevrolet Sonic
GM Platform: T200, T250, T300
2013 Sonic Won't start after pumping gas.
Old Nov 14, 2015 | 4:09 PM
foolyn10's Avatar
Default 2013 Sonic Won't start after pumping gas.
I have a 2013 Chevy Sonic that won't start only after I pump gas. I have to pump the gas pedal to get the car started. Then the car acts like it wants to stall out unless I rev the engine a bit. Any ideas what it could be? I'm thinking the purge solenoid.
Old Nov 14, 2015 | 4:43 PM
that seems like a good place to start.
remove the evap line to the purge solenoid and blow through the solenoid. if any air passes....replace the purge solenoid valve assembly.
Old Nov 14, 2015 | 11:23 PM
Brian Rockhill's Avatar
possible carbon build up on throttle body or air inlet from air filter housing to throttle body feel the big snorkel hose coming off the air cleaner to the throttle body for holes in the folds. if no holes may need throttle body cleaned. try just pushing lightly on gas pedal to slightly open throttle to see if it starts good luck
Old Nov 15, 2015 | 12:32 AM
that makes sense if the problem occurred all the time and not just at fill ups. When the purge valve is stuck open; fumes from the tank vent into the tbody and create a flood like condition.
Old Jan 1, 2016 | 4:27 PM
ihgnah's Avatar
A way I always check them is to have the car running, unplug the purge and see if it sucks air. Never thought about your way though. Sweet.
Old Jan 3, 2016 | 7:55 PM
your way is a great idea.
my way is more work but the only way I can think of for people without a scan tool to open the purge solenoid.
Old Jan 4, 2016 | 7:49 AM
cleveland63b's Avatar
I agree with purge solenoid...this threads a perfect example of how to get the same answer with different tests. I usually command it to 0% with the scanner idling and unplug the evap line and feel/test for vacuum. Unplugging the electrical connector would be basically the same I suppose
Old Jun 7, 2019 | 10:51 AM
DrUnKeN_TiGeR's Avatar
Default Sorry to raise a dead thread
I'm having this issue
​​​​​​... Is this the canister you talking about?
Old Jul 2, 2019 | 9:36 PM
Laura Ratliff's Avatar
Default 2016 sonic L T
Talked to a dealer service center and told him about the car not wanting to run well after putting gas. He said it was in the emissions system. But not the Cadillac converter so.not under warranty. Can I get the part name that would cause that problem.
Old Jul 2, 2019 | 10:06 PM
When you pump gas then you try to start the car it doesn't want to start when it does doesn't want to run.
