Sonic (Aveo) The subcompact known globally as the Aveo since 2002 is now the SONIC in North America as of the 2012 model
Chevrolet Sonic
GM Platform: T200, T250, T300
2015 chevy sonic Lt 1.8l
Old Jan 7, 2022 | 8:30 PM
mikesor's Avatar
Default 2015 chevy sonic Lt 1.8l
I replaced both oxygen sensors an still coming up with low voltage to oxygen sensors, I’m getting the 5 volt reference an 12vs and gnd, I’m starting to think it may be the catalytic converter, I check the inlet and outlet temperature…inlet temp is about 655 degrees an outlet is about 410 degrees but isn’t coming up with a cat code
Old Jan 8, 2022 | 11:01 AM
Welcome to the forum.
How many miles are on the car? It sounds a little unusual for the outlet temperature to be lower than inlet on a catalytic converter.
I'm moving your post to the Sonic section of the Forum where you will get more views.
Old Jan 8, 2022 | 11:15 AM
mikesor's Avatar
97k and using up a lot fuel
kaykay001
Sonic (Aveo)
Mar 1, 2021 7:25 PM
nkaufman
Sonic (Aveo)
Aug 27, 2020 8:42 PM
luiscanalesenriquez
May 4, 2018 9:58 PM
CableSux
10
Aug 10, 2017 10:28 PM
WyrTwister
Sonic (Aveo)
May 27, 2015 8:29 PM
