Aveo or AVery big mess?
I own a 2006 chevy aveo with 170km of relatively good driving on it and recently I've experienced a pretty big issue.
Initially the problem was that, occasionally, when I turned the car on I would find that pushing on the accelerator pedal would have no effect on the engine. I would shut the car off, turn it back on and the problem would be gone.
Last night I found the same issue happened, however at an intersection I could feel the car idling rough and when I went to accelerate through the light I found the pedal was again ineffective.
I pulled over and tried the pedal when it was in a gear disconnected from the transmission (park and neutral) and found that it would rev just fine, but in drive it had the same effect. Again, I turned the car off, waited, and on again to find it drivable.
Any suggestions aveo owners?
Throttle body problem? Gas pedal assembly?
Blackedout04
January 23rd, 2015 1:53 PM
