AVEO LS 2008 - Front speakers
Hi,
There is any diagram or manual in how to replace the front door speakers?
I cant see screws or similar in order to take out the factory speakers.
Regards and blessings.
<LI type=1>Lower the front window.
<LI type=1>Use a small screwdriver to carefully pry off the door pull handle escutcheon (2).<LI type=1>Remove the two scews (1) located behind the door pull handle escutcheon (2).
<LI type=1>Remove the inside door handle besel (1). Use a small screwdriver to pry up and release the top besel retaining clip as shown.
<LI type=1>Pry off the trim panel retaining clips (1)
blawson
Sonic (Aveo)
October 9th, 2019 9:55 PM
duckmaster1
June 2nd, 2013 10:14 AM
emery25
July 11th, 2008 3:18 PM
Ertsride1
May 9th, 2008 1:35 AM
