Aveo Sparkplugs
During this past week I have been reading forums on the, yes, you guessed right, timing belt, valves, etc. GRRR!! While I was reading, I came across a post about the plugs that someone had used that made a HUGE difference on performance and mileage and I am unable to find that post again. Can anyone help me with this? Brand, style, PART #, etc..... Thanks alot!! Joe---
![Confused](https://chevroletforum.com/forum/images/smilies/confused.gif)
I don't know about the performance issue...but Hey! I was changing the plugs on my 07Aveo and pulled out the first plug... What the heck?
There was about a quarter-cup of engine oil in the well of the plug! Has anyone seen this before?
I cleaned the oil out as best I could and the other three cylinder plug-wells had oil in them too. What gives?
Car ran/runs fine, no other issues. Does not burn oil, does not misfire, does not do anything but give me dependable transport at 30mpg.
During this past week I have been reading forums on the, yes, you guessed right, timing belt, valves, etc. GRRR!! While I was reading, I came across a post about the plugs that someone had used that made a HUGE difference on performance and mileage and I am unable to find that post again. Can anyone help me with this? Brand, style, PART #, etc..... Thanks alot!! Joe--- ![Confused](https://chevroletforum.com/forum/images/smilies/confused.gif)
Hmmm. Ok. There is no other evidence of oil anywhere near the valve cover. Lifting the plastic engine cover off the top revealed only a clean area. All the oil was in the well of the spark plugs, which are about 2" deep, with no oil on the sides of the wells. I am going to pull one of the plugs Wednesday and see if after running the car for 150miles will leave oil in there. Thanks for the thought.
Ok, so I checked the spark plug well today... no oil. There was a very light residue of oil near the opening of the well, but not enough to drip into the well itself. I am at a loss to explain where the oil came from.
melat70
August 24th, 2007 12:52 AM
