Sonic (Aveo) The subcompact known globally as the Aveo since 2002 is now the SONIC in North America as of the 2012 model
Chevrolet Sonic
GM Platform: T200, T250, T300
Aveo Sparkplugs
Old Mar 8, 2012 | 2:24 PM
JoesPC's Avatar
Default Aveo Sparkplugs
During this past week I have been reading forums on the, yes, you guessed right, timing belt, valves, etc. GRRR!! While I was reading, I came across a post about the plugs that someone had used that made a HUGE difference on performance and mileage and I am unable to find that post again. Can anyone help me with this? Brand, style, PART #, etc..... Thanks alot!! Joe---
Old Apr 21, 2012 | 3:25 PM
Dicksonrk's Avatar
I don't know about the performance issue...but Hey! I was changing the plugs on my 07Aveo and pulled out the first plug... What the heck?
There was about a quarter-cup of engine oil in the well of the plug! Has anyone seen this before?
I cleaned the oil out as best I could and the other three cylinder plug-wells had oil in them too. What gives?
Car ran/runs fine, no other issues. Does not burn oil, does not misfire, does not do anything but give me dependable transport at 30mpg.
Old Apr 22, 2012 | 9:46 AM
Aveo5_boy's Avatar
I don't think there any plugs that will give a significant improvement in gas mileage but from what I've read on other forums it is best to just stick with the OE which are the NGK's.
Old Apr 22, 2012 | 9:48 AM
Aveo5_boy's Avatar
Oil in the spark plug wells probably means you need to replace the valve cover gasket.
Old Apr 23, 2012 | 8:38 AM
Dicksonrk's Avatar
Hmmm. Ok. There is no other evidence of oil anywhere near the valve cover. Lifting the plastic engine cover off the top revealed only a clean area. All the oil was in the well of the spark plugs, which are about 2" deep, with no oil on the sides of the wells. I am going to pull one of the plugs Wednesday and see if after running the car for 150miles will leave oil in there. Thanks for the thought.
Old Apr 25, 2012 | 2:26 PM
Dicksonrk's Avatar
Ok, so I checked the spark plug well today... no oil. There was a very light residue of oil near the opening of the well, but not enough to drip into the well itself. I am at a loss to explain where the oil came from.
Old Apr 25, 2012 | 5:26 PM
EinST's Avatar
Give it time. The valve cover gasket has O-shaped segments that seal around the spark plug wells. Whatever oil that seeps out through them has nowhere to go.
Old May 23, 2012 | 2:14 PM
noracecar's Avatar
Default Plug recall
I just got a spark plug recall in the mail for my 2009 Aveo LT5
You might want to see if it applies to your Aveo.
Good Luck
Sturmvogel
Sep 29, 2008 5:49 PM
melat70
Aug 24, 2007 12:52 AM
j1999dunn
Jun 26, 2007 4:51 PM
