Venture 1997-2005
Platform: U-Body
Replacing rear sparkplugs...
Old Sep 27, 2008 | 6:51 PM
Sturmvogel's Avatar
Default Replacing rear sparkplugs...
What a freaking debacle... So far I rotated the engine forward, and removed the ICM, to get better access to the rear 3 spark plugs? No matter what I try, I seem not to be able to remove the rubber wire boots from the spark plugs; not to mention being able to get a wrench back there...
Anyone have any tips, or tricks?
Thanks in Advance,
-Kirk "The non-mechanically inclined venture owner" [/align]
Old Sep 29, 2008 | 8:25 AM
mjs182004's Avatar
Default RE: Replacing rear sparkplugs...
i ended up going from under the van. but you will need a long extension. and from the top you will need to unbolt the coils so you can unplug the rubber boots on the wires. good luck it's a pain
Old Sep 29, 2008 | 5:49 PM
shawnvw's Avatar
Banned
Those wire boots are always a royal pain in the rear. If you twist while pulling it usually helps break them free.
BobLoblah
Jul 27, 2015 5:28 AM
melat70
Aug 24, 2007 12:52 AM
j1999dunn
Jun 26, 2007 4:51 PM
