Replacing rear sparkplugs...
What a freaking debacle... So far I rotated the engine forward, and removed the ICM, to get better access to the rear 3 spark plugs? No matter what I try, I seem not to be able to remove the rubber wire boots from the spark plugs; not to mention being able to get a wrench back there...
Anyone have any tips, or tricks?
Thanks in Advance,
-Kirk "The non-mechanically inclined venture owner" [/align]
Thanks in Advance,
i ended up going from under the van. but you will need a long extension. and from the top you will need to unbolt the coils so you can unplug the rubber boots on the wires. good luck it's a pain
BobLoblah
Jul 27, 2015 5:28 AM
