Sonic (Aveo) The subcompact known globally as the Aveo since 2002 is now the SONIC in North America as of the 2012 model
Chevrolet Sonic
GM Platform: T200, T250, T300
Eeprom bcm
Old Apr 7, 2016 | 10:46 PM
sql15's Avatar
Default Eeprom bcm
need your help colleagues need dump from BCM Chevrolet Sonic with cruise control and fog lamps and 2012-2013 model year Chevrolet dump BSM cruz with cruise control and fog lamps 2011-2012 year. Thank you
Old Apr 8, 2016 | 8:50 AM
need dump?
....need explanation
Old Apr 8, 2016 | 9:51 AM
sql15's Avatar
Good day. I need to activate on my car Chevrolet Aveo T300 function TPMS, but the problem is that when the VCI request (the request is sent to Germany) comes a failure due to the fact that this function is not intended for our market. although the BCM unit similar to the unit on Chevrolet sonic USA (No. 13582620). GM MDI I have.
Old Apr 8, 2016 | 8:11 PM
so you are trying to flash software programming into the bcm.
more info required...
where do you get your programming from...are you a dealer in Germany or independant shop.
most gm's use the rcdlr for tpm data. Does the Korean made platform do the same?
Old Apr 9, 2016 | 12:26 AM
sql15's Avatar
Good morning, Yes I'm trying to program flash in BCM , I am not a dealer I bought the MDI and buy subscription to Acdelco tds Aveo and Cruz is my personal car , request to VCA programming sent from dealers but our inquiries geographically travel to Germany in the division of Opel and Chevrolet they give very bad VCA or always say that it is impossible or for Your market is not intended although Opel give always without problems, so I'm trying to program flash in BCM. I wrote a letter to GM (Good day, I am the owner of Chevrolet Cruze and Chevrolet Aveo T300 I live in Russia and want to install on my car the TPMS system has repeatedly appealed to the Chevrolet dealerships with this request and she sent a request to VCA programming but always came a denial from the Chevrolet division in Germany, with different wording, although the BCM in my car are similar to the BCM which put in the US cars and the TPMS system in the USA has after much agonizing, I bought GM MDI and a subscription Acdelco tds myself and tried to program now came to the conclusion that I need to unsolder the EEPROM chip and change the program in it, but it's just not right since I'm a good citizen and why must I do these things, I ask You to assist in obtaining VCA code for programming the TPMS system in my car and I am appealing to You because of the Chevrolet division in Germany is extremely reluctant to give VCA codes and in my case fails even though the car Opel codes sent without problems I think what division in Germany deliberately makes VCA codes for Chevrolet as it is trying to dominate the Opel. Last year I bought your Chevrolet Aveo T300 unit ABS with ESC function (code rpo FX3) installing it and sending a request for programming received VCA code which is programmed and everything worked perfectly but after some time the dealer received a letter that VCA code for FX3 was sent in error and need to remove the ABS unit installed and put the one that was installed from the factory (without FX3) and return the original programming although everything works fine and all winter I testil with a new unit with the FX3. therefore forced to turn to You as the Sheriff and have nowhere to go and beg Your assistance in resolving my issues. VIN CODE cars making KL1TA48EJCB176342 и XUFJA695JB3015648) but the answer is no and wrote on chevroletcustomercare@gm.com
Old Apr 9, 2016 | 9:12 PM
if they will not let you access the north American programming there is nothing you can do.
Old Apr 10, 2016 | 12:46 AM
sql15's Avatar
Good morning, access to the North American programming I have but when I try to program your unit under VIN code Sonic from North America (VIN code I in your unit changed in North America it changes in the EEPROM) but when I try to program the SPS says that this unit has a unknown calibration they can be more and new programming is cut off, and the VCA all requests go only to Germany as territorially registration I am in Europe and they are responsible for Europe, I can send inquiry to North America? there is the thought that someone from North America would help me ie remotely sends a request and enters their registration details, or to contact ETAC to learn how to do it. if I find a program from EEPROM BCM from the car to SONIC in North America with TPMS then I can program your BCM and change the VIN code then himself
Old Apr 10, 2016 | 9:12 AM
sorry. its very hard to understand the translation. You want someone from north America with a sonic with tpms to provide their vin?
if you have access the north American programming; and you are entering a north American build vin and the programming still won't be accepted...I do not know how to proceed further.
Old Apr 10, 2016 | 10:52 AM
sql15's Avatar
MDI program does not work because the BCM calibration is European and if i try to use North American VIN system gives me the answer: unknown calibration and programming impossible, maybe they are more recent. Although, the number of the software matches that.
I'm looking for BIN file from BCM to insert it into my BCM using the programmer EEPROM, then the system will allow to program my BCM, then I will change VIN code with EEPROM programmer.
I need BIN file for BCM Sonic
