Sonic (Aveo) The subcompact known globally as the Aveo since 2002 is now the SONIC in North America as of the 2012 model
Chevrolet Sonic
GM Platform: T200, T250, T300
help transmission issues
Old Jan 26, 2010 | 10:18 PM
duck's Avatar
Default help transmission issues
hello all i am new to this site and my problem is i have 2004 suzuki swift which is identical to the chevy aveo and also the pontiac wave my problem is with the overdrive start out on the hwy at a 100 kmph (60 mph) and use passing gear and it will not shift back into overdrive it stays in second i found out that if you shift to neutral while on hwy shut off engine and restart and reselect D4 i get overdrive back im think shift solenoid or something electric anybody else have this with the aveo , i also heard the aveo had some transmission issues a while back not sure of the year though or what the issue was any way thanks in advance for any input
also yes i have made sure the trans is full of fluid
Coravir
Oct 26, 2019 3:28 PM
01yeehaw94
Mar 29, 2008 8:41 PM
