Sonic (Aveo) The subcompact known globally as the Aveo since 2002 is now the SONIC in North America as of the 2012 model
Chevrolet Sonic
GM Platform: T200, T250, T300
Involvement of the front fog lamp Aveo (Sonic) T300
Old Aug 4, 2016 | 2:44 PM
kekypetrakeky's Avatar
Default Involvement of the front fog lamp Aveo (Sonic) T300
Hey guys already know where to ask. I kept engage front fog lights from one service firms. Fog lights were purchased as unoriginal but everything fits as a light bulb and it's just the same as the originals.
So they exchanged a plastic housing and installed fog lights and pulled extra cabling because the car was not preparation for a front fog lights, and here is my problem.
I wanted to make it from the company involved as it is the factory that lit up the light on the dashboard and switch worked just as it should be.
When I pick up the car, so I argued that a switch which I supplied them does not work.
But the connector wire is already ready.
But I've found and compared with another Chevy that the switch works, but the lowest in the connector that is connected to the switch, one wire, and I suppose it's switching to those mentioned fog because everything else is working as it should.
I attach photos.
I would be grateful if someone could explain or something similar already solved where I connect the wire and if you happen to low- and fuse boxes already prepared The relay or where to connect.
Attached Thumbnails Involvement of the front fog lamp Aveo (Sonic) T300-wp_20160801_09_03_17_pro_li.jpg   Involvement of the front fog lamp Aveo (Sonic) T300-wp_20160801_09_07_39_pro_li.jpg   Involvement of the front fog lamp Aveo (Sonic) T300-wp_20160801_09_07_51_pro_li.jpg   Involvement of the front fog lamp Aveo (Sonic) T300-wp_20160801_09_09_00_pro_li.jpg   Involvement of the front fog lamp Aveo (Sonic) T300-wp_20160801_09_09_29_pro_li.jpg
Involvement of the front fog lamp Aveo (Sonic) T300-wp_20160801_09_10_44_pro_li.jpg   Involvement of the front fog lamp Aveo (Sonic) T300-wp_20160801_09_11_51_pro_li.jpg   Involvement of the front fog lamp Aveo (Sonic) T300-wp_20160801_09_13_44_pro_li.jpg   Involvement of the front fog lamp Aveo (Sonic) T300-wp_20160801_09_14_00_pro_li.jpg
