Spark Originally known as the Beat, , this Daewoo Matiz based 5 door hatchback is newest to the Chevrolet lineup
Chevrolet Spark
Shifter Cable (manual) Transmission
Old July 28th, 2024, 1:27 PM
Amazone's Avatar
Default Shifter Cable (manual) Transmission
2018 Chevy spark stick shift.
Issue: the shift lever was loose & gears were not engaging ,indicating a bad shifter cable. The cable was removed ,inspected and compared to another cable side by side. All was good. In the interim, it was noticed the the SHIFT LEVER on top of the transmission was also loose and not accepting engaging any gears.
Typically if a cable breaks, one can put the car into gear from the lever on top of the transmission. In this case nothing happens . This Lever can be moved up or down , side to side & one can't even hear the gears grab when one moves the lever. Really strange.
Any thoughts , ideas ,tips in the right direction would be appreciated. Thanks
Old Yesterday, 9:07 AM
Amazone's Avatar
*bump*
Old Yesterday, 9:41 AM
Take the covers off and look for broken parts.
tree climber
October 14th, 2023 2:14 PM
dwoerman
May 10th, 2015 9:42 PM
phord
July 14th, 2011 7:35 PM
Brick top
May 8th, 2010 7:14 PM
squarepeg
April 8th, 2010 7:18 PM
Quick Reply: Shifter Cable (manual) Transmission
