Suspension & Tire Is your ride slammed to the ground? Did you lift it so high you need a ladder to get in? Got sleek low-pros or gnarly mudders? Step in and let's talk about 'em!
lowering s-10 blazer
Old February 23rd, 2006, 1:02 AM
jagblazer01's Avatar
Default lowering s-10 blazer
I have a 2001 s-10 blazer 4x4 and i want to lower it. Who makes a good lowering kit for my truck. Im looking to lower it 4"
Old July 24th, 2006, 8:10 PM
NCHEVYHEVN's Avatar
Default RE: lowering s-10 blazer
This is a really old thread but incase anyone wanted to know or if you still wanted to know then here you go.
I beleive on the 4wd that beltech makes drop keys. I don't know if thier any good or not but I think you can get 2 or 3 inches from that. That last inch or two is going to have to come from cranking the torsion bars.
For the rear you get a 4' block or you can combine a 1' block with a 3' lowering leaf springs.
Old February 11th, 2007, 11:55 PM
shnormo's Avatar
You're going to have to notch out your frame if you want to go that low. you're also going to have to adjust your drive shaft pinion angles.
mattintc
August 14th, 2012 11:36 AM
06NBPsi
Suspension & Tire
October 11th, 2006 2:40 PM
Black 5.3
August 17th, 2006 10:05 PM
csbs13
Silverado & Fullsize Pick-ups
May 26th, 2006 1:05 PM
K9TAHOE
May 18th, 2006 4:00 PM
Quick Reply: lowering s-10 blazer
