Suspension & Tire Is your ride slammed to the ground? Did you lift it so high you need a ladder to get in? Got sleek low-pros or gnarly mudders? Step in and let's talk about 'em!
Rim/Tire question
Old May 26th, 2011, 9:16 PM
msp95713's Avatar
Default Rim/Tire question
What do i need to do if i want my tires to stick out from the body of my truck? Do I get negative or positive offset rims??
Old July 3rd, 2012, 1:19 PM
SWHouston's Avatar
Offset is "quoted" the same as is Camber.
Toward the outside is positive, toward the inside is negative.
Most times, the only requirement to be a Tire Salesman, is having worked a Burger King, or Jack in the Box for over one week.
YOU do the research, YOU take your measurements, YOU decide if it's right for you, and then YOU KNOW it's right.
Old July 9th, 2012, 12:43 PM
Former Sponsor
TireOnDemand's Avatar
Thumbs up
Hello! Negative Offset wheels will make your tires stick out while Positive offset wheels will make your tires tucked in from your Factory OEM Range Offset. Let me know what vehicle you have so i can let you know what's the maximum recommend negative offset you can go. It really depends on what stock offset your vehicle have. You can click this link for reference that you can read on... Take note on the mounting pad. Backspacing and offset UPDATE! - S-10 Forum
Attached Thumbnails Rim/Tire question-images.jpg   Rim/Tire question-images1.jpg
Old July 9th, 2012, 1:20 PM
SWHouston's Avatar
Yep, just like I said
Who do you trust...
What is rim offset? - Tire Rack Team Blog | Tire Rack
rickp
December 6th, 2012 10:33 PM
Phil.Hugi
Silverado & Fullsize Pick-ups
August 29th, 2012 12:20 PM
cbarry77
September 2nd, 2011 11:01 AM
country_09
November 9th, 2009 3:04 PM
gruichn1
August 10th, 2007 11:12 AM
Quick Reply: Rim/Tire question
