'01 Sub, Removing Tape Deck
I and some friends have been using CBs to talk when we go camping. There is no cell reception, and this is a reliable form of communication. I would like to take the tape deck out and insert my CB where it is. Ive done a rough estimate, and I think my CB will fit inside of that area. Can someone tell me how to get to the tape player area to take it out?
Thanks
Thanks
RE: '01 Sub, Removing Tape Deck
Did you get this done yet? When you flip up the storage lid underneath the tape deck there are two hex head screws 8mm I believe. Take those out and you can remove the plastic molding. Then you can see that the tape deck is mounted in with some kind of snap system. Get a screw driver and slightly pry the snaps back and it should just slid right out. The hardest part is disconnecting the wires from the back. They have a snap clip on them as well so you have to squeeze and pull to get them disconnected.
zachflauaus
May 31st, 2008 6:47 PM
