'01 Sub RPM's surge/drop with AC on
Old Jan 6, 2009 | 10:37 AM
drnls's Avatar
Default '01 Sub RPM's surge/drop with AC on
I have a 01 Sub with 125,000 mi. Has original plugs/wires, change oil when light comes on and use Mobil 1 syn 5w/30, change trans fluid between 30-40,000 mi. Probably needs new fuel filter, had fuel pump changed with wiring harness recall. Recently changed the belts. Lately when the AC is on (cold now but still does it) and at a stop light or idle the RPM's and engine surges down - almost like it is going to stall but never does. Then when accelerating it ever so slightly stumbles and then drives fine until the next stop. If I turn off the AC then it runs fine. Suggestions - alternator, plugs/wires? I am a DIY so let me know what you think. Thanks, Nelson
Old Jan 6, 2009 | 8:57 PM
MDTAHOE's Avatar
Professional Mechanic
Default RE: '01 Sub RPM's surge/drop with AC on
Clean throttle body and clean or replace IAC (idle air control). The IAC is used to keep the idle up as the load is increased.
Old Jan 7, 2009 | 10:24 AM
drnls's Avatar
Thanks! nls
Old Jan 22, 2009 | 8:50 PM
jkgray80's Avatar
Sounds like compressor is starting to go (locking/dragging). Did you change the belts b/c they had to remove the main belt to replace the broken A/C belt?
Old Feb 16, 2009 | 9:54 AM
drnls's Avatar
Default No IAC on 2001
I finally got around to cleaning the IAC, but there isn't one on a 2001. So I removed the throttle body and cleaned it. While driving yesterday, turned on the AC and it was down surging again. Any ideas for what else could be causing this? Thanks, Nelson
CADru
Sep 28, 2019 7:26 AM
smittyd
Aug 15, 2015 4:11 PM
alkaspeltzar
Jul 31, 2013 8:32 PM
sedmonds
Sonic (Aveo)
Oct 6, 2008 10:44 AM
davids_az
Nov 1, 2005 3:29 PM
