01 Suburban engine knocking
Old Jun 15, 2011 | 12:20 AM
exclus's Avatar
Default 01 Suburban engine knocking
Hello... I have a 2001 Chevy Suburban with about 160,000 miles. The other day I noticed an engine knock and had my wife take the burb to our mechanic. He thought it was the belt tensioner but after replacing it the knocking sound was still there. he than removed the belt and ran the engine and it still knocked. It doesn't appear to robbing power but it does get louder as you accelerate the car. Could it be the timing chain? I would think this motor would get more than 160K before grenading. It does burn some coolant not much though. I also noticed the "service engine" light coming so I'll check to if he downloaded any codes. Thanks in advance for your help!
Old Jun 20, 2011 | 9:16 PM
Knocks are usually bearing related. Have you had since new?
Old Jun 21, 2011 | 7:34 PM
ChevyGuy Tyler's Avatar
I had the same problem in my 01 Tahoe it was a loose rod.
Old Jun 21, 2011 | 8:51 PM
If your oil is even slightly milky then its most likely bearing wear causing the knocking....a connection rod cap would make more of a clicking or tapping sound..knocking is something bigger moving around....
Old Jun 21, 2011 | 9:00 PM
ghost-wolf's Avatar
I would check the lifters.if its a tink tink tink sound.and if it gets faster when you give it gas.
Bill's Dad
Oct 20, 2009 7:51 PM
dei3rules
Jul 18, 2009 8:56 PM
WHEELIN
Jun 9, 2009 1:31 PM
kmatassa
Apr 1, 2009 6:57 PM
piniongear
Jul 9, 2008 10:31 PM
