01 Suburban IGN 3 Fuse Blown and Rear A/C Not Working
I have an 01 Suburban 1500 and recently I have done some work to it (Window Regulator, Factory AMP replaced with Factory AMP and Driver Seat Track Assembly). About a week later, my rear A/C went out. Front is fine but I am also blowing the STUD1 30AMP fuse in the front fuse block and when the car auxiliaries are on or I turn the car on, the ING 3 fuse in the drivers side fuse internal panel blows immediately.
So far, I've determined there is power to the AC Control module but not to the blower. I lead-jumped the blower and when it has power, works fine. Pulled an AC Control Module and the two rear auto A/C controls from a salvage yard and replaced them. Still blowing fuses. I checked the Air Ride Compressor and it is completely magnetized and not working. I've disabled that and still blowing the ING3 fuse. Any suggestions? I am losing my mind.
I`m having the same issue with a 2000 Chevy Tahoe....ie. IGN3 FUSE BLOWING....
Using a test light with tone it should be easy to find the short but noooooooo.
Anyone else ran into this same problem, please post the resolution.
Thanks, Scott C.
Thanks, Scott C.
the Wizard
September 26th, 2020 5:20 PM
