01 Tahoe Climate Control Not functioning properly
Old Nov 29, 2021 | 1:14 PM
BartBenoit's Avatar
Angry 01 Tahoe Climate Control Not functioning properly
Hi!
I drive a 01 Tahoe and my climate control (non digital) isn't working as it should. When I put the temperature **** on cold, I get heat. When I put it on heat, I get cool air. And the system only blows cool air to the defrost and front vents. It doesn't blow to the floor. A/C isn't the coolest either. Any ideas on where the issue may lie?
Thanks
Old Nov 30, 2021 | 7:32 AM
Cusser's Avatar
Sounds like an actuator problem; these little motors move the air flaps in the vent system; these are located under the dash. My 2005 Yukon had three of these, and I had to replace one, and then get the ECU to "learn" it. My previous 1994 also had an actuator issue but a shop replaced that one.
Old Nov 30, 2021 | 10:07 AM
BartBenoit's Avatar
That makes a lot of sense. Thanks for the feedback! I'll be sure to post my results after I check them
Old Dec 6, 2021 | 6:01 AM
dannymax78$'s Avatar
Originally Posted by BartBenoit
Hi!
Thanks
It might be the blower motor resistor.
Old Dec 6, 2021 | 7:15 AM
repairman54's Avatar
Not if it's a temperature issue and it's blowing air.
Sharpshooter23
Feb 4, 2020 9:30 PM
shivers44
Feb 25, 2012 11:07 AM
RacerX
Mar 9, 2011 9:47 AM
Joepoppa1
Oct 4, 2009 11:20 PM
Larryrb
Jul 1, 2009 2:27 PM
