02 chev tahoe misses under light load
Old May 27, 2014 | 4:06 PM
jimmer6776's Avatar
Default 02 chev tahoe misfires under light load
I have a 2002 Chevy Tahoe that I recently had the solenoids replaced in transmission because my check engine light was on and after getting the Code read indicated a Fault which corresponded with my trans slipping in passing gear or after downshifting into a turn, problem solved, code cleared, within a half hr truck started to misfire or hiccup under light load in overdrive, if I put truck in 3rd or pushed tow button it seemed to go away, truck has 5.3 l with 200,000 miles and runs like a champ any other time and before replacing solenoids
Old May 27, 2014 | 9:15 PM
Possibly something got disturbed when the solenoids were replaced. Any DTCs w/ the "misfires"? I'd check any connectors that might have been disturbed.
Old May 27, 2014 | 9:25 PM
jimmer6776's Avatar
I'm thinking it's just a coincidence about solenoids because I found quite a few threads online with the same problems but no real solid answers except change plugs and wires, so that's the next thing , I get no codes right now so no help there
Breze84
Oct 31, 2019 4:34 PM
dslemaire
Aug 23, 2018 9:46 PM
jimmer6776
May 27, 2014 6:53 PM
rteas48183
Mar 18, 2008 4:59 PM
harold
Apr 6, 2007 3:20 PM
