02 sub leaking coolant
Old Dec 30, 2008 | 11:05 PM
mikehe's Avatar
Default 02 sub leaking coolant
i have a leak somewhere, it dosent look like its coming from the top of engine, hoses dont show any signs of fluid, on the underside i see the fluid around the oil pan, is there a seal or water pump in the area, please send any suggestions.
Thanks
Old Jan 3, 2009 | 2:14 PM
cincysuburban's Avatar
Default RE: 02 sub leaking coolant
Sounds like the water pump is leaking. Thats why mine did. So much stuff in the way its hard to see anyting but I kept seeing the coolant on the underside. I would suggest to replace the belt tensioner with it sing you have to take it off anyways. Mine went bad 10,000 miles after I did the water pump.
isaacsnr07
Jan 12, 2010 9:36 PM
MarkIV396
Camaro
Apr 20, 2009 2:29 PM
hdsteve55
Jan 2, 2009 8:23 AM
SuperTexan
Oct 30, 2008 8:12 PM
blkclipse
May 24, 2008 8:15 PM
