02 Suburban 4X4 Output Shaft Engaged
Old Oct 30, 2011 | 12:34 PM
Chevy2011's Avatar
Default 02 Suburban 4X4 Output Shaft Engaged
Greetings, I believe I am having trouble with the transfer case on my 02 Suburban. I am hearing a clanging noise when I put it in gear and vibrations at hiway speed. Also a squeeking sound which sounds to be driveshaft/transfer case related. I put it on blocks today and did find a bad u-joint at the rear differential, but don't think this could be the whole problem.
Also noticed a little radial loosness at the rear output shaft of the transfer case.
Also noticed the output shaft to the front axle turns with the rear drive shaft. Is the front output shaft supposed to be engaged at all times, even when not in 4 wheel drive?
Any suggestion would be greatly appreciated. Thanks
20020 Suburban 1500 4X4 (180,000 mi.)
Old Nov 2, 2011 | 11:16 PM
cooter26's Avatar
For the front driveshaft. The actuator in the transfercase engages power from the transfercase to the driveshaft when engaged, the other actuator in the front axle engages also when you switch into 4x4. If your switch is in AWD the transfercase is engaged spinning the front driveshaft but leaving the axle disengaged. Even in 2wd mode some of the spinning motion in the transfercase is transfered to the front driveshaft causing it to rotate. Bad u joints and bearings in the double cardigan joint if you have one can cause major vibration and road noise even if the vehicle is in 2wd mode.
mhp8982
Feb 16, 2011 9:13 PM
mryamaha
Jan 15, 2011 9:04 PM
slovcan
Oct 25, 2009 10:26 AM
kroekermichael
Cobalt
Jan 28, 2008 8:36 PM
ckadoun
Feb 27, 2007 11:14 AM
