02 Tahoe 5.3L flex fuel filter replacement
Old Feb 21, 2020 | 7:46 AM
tahoe64gg's Avatar
Default 02 Tahoe 5.3L flex fuel filter replacement
Has anyone used the Lisle 35000 quick disconnect tool on fuel line filter fitting for the 02 tahoe 5.3L? How good did the tool work? I saw on amazon not to use the tool. Thanks for replies and suggestions.
Terry
Old Feb 21, 2020 | 8:43 AM
Irish_alley's Avatar
I'm here for the party
where you trying to use it at? on the fuel line on the engine the normal fittings work well but if im thinking right the one on the tank doesnt work too well because theres no room to put the tool
Old Feb 21, 2020 | 2:22 PM
tahoe64gg's Avatar
I am changing the fuel filter from the tank to to the engine that is located under the drivers side door. Thanks
Old Feb 29, 2020 | 9:49 AM
tahoe64gg's Avatar
Thumbs up
Terry
I got my fuel filter changed yesterday. I had to take to the local mechanic $30.00. I tried using the quick disconnect, but it was very hard to get the pieces on the fitting without them falling off. There are videos on youtube showing the replacement. I would suggest to take the filter off the bracket and use the Lisle 35000 tool which make better access to the fitting. I should have done this when i was trying to remove the filter.
Fadel
Mar 26, 2018 8:38 AM
jcgonzal
Apr 26, 2011 6:34 PM
DNIC75
Nov 16, 2008 3:47 PM
DougBennett
Dec 26, 2007 3:54 PM
gilbertnewcomb
Oct 31, 2006 2:19 AM
