02 Tahoe throwing codes
Old Aug 9, 2009 | 3:43 PM
joatman's Avatar
Default 02 Tahoe throwing codes
2002 Tahoe Z71 flex, changed failed fuel pump assembly last week and went on a highway trip, of about 300 miles and oil light came on. Checked oil and needed to add about 4 qts. No leaks, so i checked pvc and it was plugged. Changed pvc and drove back and oil level seems to be ok. But this is where it starts to throw a bunch of codes and is running rough.
P0178: Fuel Composition circuit low input
P0207: cly 7 injector
P0226 Throttle PetalSensor/ Switch problem
P0301 #1 misfire
P0302 #3 misfire
Trying to determine common denominator...any suggestions welcome.
Last edited by joatman; Aug 10, 2009 at 8:09 AM. Reason: clarify fuel pump assembly changed
Old Aug 9, 2009 | 10:19 PM
MDTAHOE's Avatar
Professional Mechanic
Did you have the fuel filter changed when the pump was changed?
Old Aug 9, 2009 | 10:38 PM
joatman's Avatar
Default fuel filter
No, but it was changed within the last year.
Old Aug 12, 2009 | 8:45 AM
joatman's Avatar
Default cleaning
Update, cleaned Throttle body and used injector cleaner in gas, after another highway trip the only code left is p0178, but running great.
Eddie02780
May 11, 2015 3:08 PM
Gavin Collins
Cobalt
Aug 30, 2012 5:32 PM
mapsurfer
Mar 1, 2011 7:04 AM
TheDash
Dec 24, 2010 8:21 PM
PastorK
Feb 17, 2010 9:31 PM
