02 Tahoe Z71 No electrical power
#11
Like someone said in an earlier post you may wanna try tapping it while trying to start and see if it does anything. Or you could just check the voltage that it is sending to the starter while someone is turning it over.
#12
If your battery is dropping to 4-5 V in the start position, then the battery is shot or the starter motor has a serious problem.
Have you tried charging the battery?
#14
#15
Pulled the battery and starter out of the Tahoe and took them be tested. Both tested good.
#16
<o></o>
Any idea what the voltage should be to the small wire attached to the solenoid<o></o>
jimmy_sleevage
March 8th, 2011 3:41 PM
Igotasilveradonstuff
December 2nd, 2010 2:57 PM
