03 Chevy Tahoe engine issue
Old Jul 22, 2021 | 10:03 AM
Truckman77's Avatar
Default 03 Chevy Tahoe engine issue
2 months ago I had a 2003 Chevy Suburban that I wrecked. I purchased a 2003 Chevy Tahoe that did not have a engine. I had the engine taken out of my wrecked Suburban and put in the Tahoe. Once everything was completed. I started the Tahoe up, it has a misfire and is puttering when I drive it. I sometimes get a message on the dash engine power reduced, when this happens I have no power when I press the gas petal and the truck goes nowhere. I had a street mechanic look at it and was told I need a new ECM or computer. Can this be true? Please advise. Thanks
Old Jul 22, 2021 | 10:31 AM
oilcanhenry's Avatar
Yeap. Pull the old one out of you Burb if you can. Might have messed up something in the crossover as well. Put ii on an an OBD II code reader and post the results. A street mechanic who only owns a cheap OBD reader, if that, is NOT who you need to have this done properly
Old Jul 22, 2021 | 10:54 AM
Truckman77's Avatar
Should I order a new programmed ECM by vin number for the suburban or the Tahoe?
Old Jul 22, 2021 | 6:07 PM
Possibly, if the original does not work. There are techs who may be able to reprogram the ECU for you.
Maddy Mry
Sep 20, 2017 6:05 PM
Nathan408
May 19, 2017 4:45 AM
blackcrow
Sep 18, 2014 3:45 AM
plarent
Jun 21, 2012 7:59 AM
livinlo
Dec 19, 2006 12:00 PM
