03 suburban blend door
Old Oct 28, 2020 | 10:17 AM
  #21
cchucky51's Avatar
i did try amazon didn't work
i ask about scanner as an option
Old Oct 28, 2020 | 10:34 AM
  #22
PNW NBS Z71's Avatar
Ok, well you tell about it but then don't say that you tried it till I asked. I learned a long time ago not to assume things so I asked. Any help you get here comes from what you are asking and telling us. Bits and pieces of info and unsaid information helps no one.
A scanner does you no good if you don't know how to use it or analyze what it is telling you. Did you look thru you tube videos for info on replacing the actuator and what steps are required after you do? Again, you may assume we know you did but correct is better.
Old Oct 28, 2020 | 10:42 AM
  #23
cchucky51's Avatar
Exclamation
sorry if i am confusing
i did look on you tube and did follow all directions they had provided and all there looked like every thing worked as soon as hooked up there was an earlier post that cusser had posted and i followed his directions and nothing i hope this helps you understand
i guess I'll just call the shop i deal with and let him look at it was hoping to save some cash every time i take truck to him it's 3-400 bucks
thanks for all your help
Old Oct 28, 2020 | 11:25 AM
  #24
There is never a problem asking questions here but is always best to have complete and thorough info feedback. Sometimes you run in to something like this where all attempts at help and giving info does not work out. I am still leaning toward the control head in the dash but again, that is a WAG. Good luck and please post back here when you get the problem solved, with all info that was done to fix the problem. Thanks.
Old Oct 28, 2020 | 2:48 PM
  #25
cchucky51's Avatar
Exclamation
i just went out to take unit out to get part number
and it seems that this must of been an issue before because the part i took out had a build date of 09/15 model 21997352
Old Oct 28, 2020 | 2:55 PM
  #26
Yea, definitely not the original from 2003. Does the one you have show a part number that matches or crosses to it?
Never mind, I found that the 15189436 and the 21997352 all cross to either to the new or reman Dorman number at RA. 599001 is the reman Dorman number and 599210 is the new Dorman number. At RA. Price plus shipping but I bet is available at Amazon for a little more for free shipping.
Old Oct 28, 2020 | 3:15 PM
  #27
cchucky51's Avatar
Exclamation
didn't see one but rock auto claims that both numbers show same unit 21997352/ 15189436 for this truck i tried to upload from phone
Old Oct 28, 2020 | 4:08 PM
  #28
At Amazon:
Amazon Amazon
Both listed as new but with different numbers. The new Dorman number of 599210 shows both the numbers, 15189436 or 21997352, as crossover numbers for the two Dorman numbers.
Old Oct 29, 2020 | 4:47 AM
  #29
cchucky51's Avatar
kind a hard to think it's the controller when it's only 5yrs old dorman has a video and i am going to try there way oy of calibration
Old Oct 31, 2020 | 7:29 AM
  #30
cchucky51's Avatar
Hello so yesterday rain stopped and went out to truck and tried 3 different types of calibration none worked on the actuator i could hear it run through a series but not to the actuator the i needed tried both old one and new one
so sending back new one and they are sending another one and got a head unit from ebay which is guarantied to work
so saga continues if nothing here will be taking to shop but as of right now still under 100 bucks won't know any thing till late next week
THANK you for all your HELP
God Bless and be safe
