03 Suburban front seat heater shorted
Old May 21, 2015 | 12:48 PM
Chopperdoc's Avatar
Default 03 Suburban front seat heater shorted
I just picked up an 03 Burb. The driver’s leather is pretty cracked up and the seat heater doesn’t work. Can anyone tell me what years will a direct bolt be in if I find replacements?
If not, has anyone troubleshot the seat heater? The switch has power. When you select either back or both elements the switch light comes on momentarily but won’t stay on. I’m thinking either a shorted wire or a shorted element.
Old May 21, 2015 | 8:31 PM
Welcome to the forum. Probably 2001 through 2006 seats would work. You said you had power to the switch but does that power, when the switch is On, get to the heater element? If it does and you still don't get any heat, then the element is most likely open. You can check that with an ohmmeter.
Old May 22, 2015 | 11:25 AM
Chopperdoc's Avatar
Thanks
Gonna try to get to it this weekend. Got to change plugs and plug wires and do all four brakes first.
Have a good weekend
Gilley_man
Nov 13, 2014 9:48 PM
csennett0503
Nov 11, 2014 1:33 PM
Annaleigh
Jun 6, 2014 1:32 PM
primesuspect
32
Sep 8, 2011 8:44 PM
harczak80
Apr 19, 2006 8:56 PM
