'04 Autoride problems
Old October 5th, 2008 | 7:50 AM
gofor35off's Avatar
Default '04 Autoride problems
The Autoride on my '04 has failed. The compressor failed about 8 months ago and now I have a "clunking" coming from the driver's side rear shock absorber and the boot surrounding it appears torn. The ride quality has also deteriorated noticably.
First, what does Autoride do? I know it manages the load levelling rear suspension, but does it also affect ride quality during everyday everyday driving? If it does manage the ride, would it still have been working even with the failed compressor? The replacement compressor is about $500 and the Autoride rear shocks are also $500 each so by replacingthese 3 parts I'm into somes pretty serious $ with no guarantee it is all fixed (there are alot of sensors and wiring connected to the suspension).
I can live without the auto load-levelling. What if I just replace the 2 rear shocks with good quality Monroes specified for non-Autoride 'burbans? Will they fit? I assume this would improve the ride just by removing the blown rear shock for much less $.
Any advice??
Thanks.
Old October 7th, 2008 | 12:15 AM
newdriver's Avatar
Default RE: '04 Autoride problems
check arnottindustries dot com for your suspension system. cheaper than dealer.
http://www.prnewswire.com/cgi-bin/st...2238149&EDATE=
Old October 12th, 2008 | 7:12 AM
gofor35off's Avatar
Thank you for the tip. I will order the shocks & compressor, give it a try and report on results.
Regards,
Old October 19th, 2008 | 4:29 PM
SabrToothSqrl's Avatar
wow, that makes me nervous about a new truck w/the autoride... i hate it when parts fail! let me know... an 04 isn't that old, but obviously out of warrenty... if it were me, I'd scrap the autoride, and just bolt on some 'normal' shocks...
Old November 2nd, 2008 | 2:58 PM
newdriver's Avatar
you cannot just put a regular shocks in them (autoride option) your DIC will display to "service autoride". if you go that route, have your bcm reprogrammed ( not to include the rtd z55 option i guess).
Faceman
September 5th, 2024 8:19 PM
Nic.Pollinger
March 25th, 2014 2:17 PM
riverst
March 8th, 2009 1:00 AM
tromblz
May 8th, 2006 3:10 PM
