'04 Autoride problems
The Autoride on my '04 has failed. The compressor failed about 8 months ago and now I have a "clunking" coming from the driver's side rear shock absorber and the boot surrounding it appears torn. The ride quality has also deteriorated noticably.
First, what does Autoride do? I know it manages the load levelling rear suspension, but does it also affect ride quality during everyday everyday driving? If it does manage the ride, would it still have been working even with the failed compressor? The replacement compressor is about $500 and the Autoride rear shocks are also $500 each so by replacingthese 3 parts I'm into somes pretty serious $ with no guarantee it is all fixed (there are alot of sensors and wiring connected to the suspension).
I can live without the auto load-levelling. What if I just replace the 2 rear shocks with good quality Monroes specified for non-Autoride 'burbans? Will they fit? I assume this would improve the ride just by removing the blown rear shock for much less $.
Any advice??
Thanks.
Any advice??
Thanks.
check arnottindustries dot com for your suspension system. cheaper than dealer.
http://www.prnewswire.com/cgi-bin/st...2238149&EDATE=
wow, that makes me nervous about a new truck w/the autoride... i hate it when parts fail! let me know... an 04 isn't that old, but obviously out of warrenty... if it were me, I'd scrap the autoride, and just bolt on some 'normal' shocks...
you cannot just put a regular shocks in them (autoride option) your DIC will display to "service autoride". if you go that route, have your bcm reprogrammed ( not to include the rtd z55 option i guess).
Nic.Pollinger
Mar 25, 2014 1:17 PM
