04 Chevy Tahoe Z71 4wd problems
Old Nov 25, 2019 | 8:05 AM
steiner093's Avatar
Default 04 Chevy Tahoe Z71 4wd problems
My 4wd will not engage. When shifting from 2 high to 4 high, the light on the buttons blink and appears to switch over to 4wd but I cannot hear it engage and it actually does not engage. So, despite the display saying it is in 4wd, it is not.
When switching from 2 high or 4 high to 4 low, I put it in neutral, hit the button, the light blinks and appears to switch over, I can hear it clunk like it is engaging but again it does not actually engage into 4 low. The display again says it is in 4 low, but it is not. I put it in neutral and hit the 2 high and it clunks to shift to 2 high, the button display now shows 2 high but as mentioned before it was never actually in 4 low to begin with.
I am going to grease up the zerks today and check the ground wire as I have seen mentioned in other threads but checking to see if anyone has any other suggestions.
Thanks in advance!
Old Nov 25, 2019 | 5:00 PM
oilcanhenry's Avatar
Thanks in advance!
Likely actuator motor is gone. That or the TCCM is malfunctioning. Check for loose or corroded wires first however.
Scott B
2007 - 2013 (GMT900)
Jan 26, 2017 12:23 PM
Bearman68
Jan 4, 2016 2:02 PM
Brosebo
Jan 9, 2013 4:45 PM
cjb3303
Feb 21, 2010 7:31 PM
tedsfam
Jul 6, 2009 10:49 PM
